Hi all,
Is it possible to get the CPU's machine cicles from a C script? I'm using the C Scripting feature of the uVision3, and I need to syncronise the scripts with the simulation. For example, i need to have a C script that will togle a pn after a specific number of machine cicles.... Is it possible?
Best regards, Marius
Hope this will help you.
Configure a timer in auto reload mode and assign the source of the timer as sysclk/1. You can check the timer value to get a count on sysclk cycles. If your desired value exceeds the size of the timer then you have to handle the situatiuon using the ISR of the timer.
HOW?
since no derivative has been stated i doubt he is using a derivative where that is possible.
Erik, if he is using such a derivative, he can make use of my post. Or even if he is using different system clock and timer clock, he can just calculate the ratio between the two clocks and use the same procedure to get the number of sysclks.
Anyway, thanking for reminding me this point.
