Dear, I just downloaded the evaluation version of latest C166 Compiler. When I'm going to compile one of the examples "RTXtiny (RTX_EX1.Uv2)" under EC++ subfolder in examples folder i get this Error: *** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\KEIL7.XX\C166\LIB\RTX167HL.LIB What happend? Thanks.
*** FATAL ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: C:\KEIL7.XX\C166\LIB\RTX167HL.LIB what happened? the tools looked for rtx167l.lib and didn'd find them at this location. Make sure the file exists there. This is an add-on isn't? Did you actually purchase it (RTX that is)? Andy
Dear, Is RTX is an addon on C166?or it isn't but not included in Evaluation version? (I just installed the latest availble evaluation of C166 without any problem or error) I download Evaluation version of C166 compiler to compare it's optimization with other c compilers available in the market and decide to purchase the best one (in my opinion). Thanks.
The RTX is an add on package for the 8051 tools, so I imagine it is for the C166 too. If your only evaluating the optimizing capabilities, why not leave the RTOS stuff alone for now? Good Luck Andy
