I have used the trail and full Uvision3 ARM compiler. The following code produces the error 'expression must have a constant value' at the indicated position below. The same code compiled on about 5 other different compilers(microchip, borland, microsoft etc) results in no error. Can anyone help. /////////////////// typedef struct { unsigned char A; unsigned char B; unsigned char C; unsigned char *STR; unsigned char L; long F; }EDIT; typedef struct { unsigned short S; void* (*ptr)(void*); unsigned char *BI; unsigned char IDx; unsigned char IDm; unsigned short M; unsigned short tMask; unsigned short *tStatus; }FUNCTION_KEY; unsigned char NullCall(void){return 0;} int main(void) { EDIT Profile= { 2, 20, 8, "\x12", 14, 0x12345678 }; FUNCTION_KEY FKey_Title[1]= { 0x1234, (void*(*)(void*))&NullCall, "\x30", 0, 1, 0x1234, 0x1234, (unsigned short*)&Profile.F, // error: expression must have a constant value }; }
You are defining Profile as an automatic variable that is located on stack. Therefore the address of this variable cannot be represented as a constant. You have two options:
static EDIT Profile=...
