error: #28 expression must have a constant value
I have used the trail and full Uvision3 ARM compiler.
The following code produces the error
'expression must have a constant value' at the indicated position below.
The same code compiled on about 5 other different compilers(microchip, borland, microsoft etc) results in no error.
Can anyone help.
typedef struct
unsigned char A;
unsigned char B;
unsigned char C;
unsigned char *STR;
unsigned char L;
long F;
}EDIT;
typedef struct
unsigned short S;
void* (*ptr)(void*);
unsigned char *BI;
unsigned char IDx;
unsigned char IDm;
unsigned short M;
unsigned short tMask;
unsigned short *tStatus;
}FUNCTION_KEY;
unsigned char NullCall(void){return 0;}
int main(void)
EDIT Profile=
2,
20,
8,
"\x12",
14,
0x12345678
FUNCTION_KEY FKey_Title[1]=
0x1234, (void*(*)(void*))&NullCall,
"\x30",
0,
1,
0x1234,
0x1234,
(unsigned short*)&Profile.F, // error: expression must have a constant value
