Program Size: data=63.0 xdata=0 code=1832 How do i calcuate the size of flash memory of controller required for the above program size?What does the above information indicate? P.S.:The program was compiled in Keil UV2
your code size is 1832 bytes long your code is using 63.0 bytes of the RAM And you are not using any bytes of the XRAM ...How do i calcuate the size of flash memory of controller required for the above program size... It should greater than code size.
code size + constants size. (Constants, including C initializers, have to be stored in non-volatile memory.) "data" refers to the internal 128/256 byte data memory space of the 8051. "xdata" refers to the 64KB external memory space.
