hi all
i was trying to communicate the LPC2119 through UART0 module and PC( Hyper Terminal). the code is as follows.
#include<LPC21XX.H>
#define bitset(var,bitno) ((var) |=1<<(bitno)) #define bitclr(var,bitno) ((var) &=~(1<<(bitno)))
#define TEMT (1<<6) #define LINE_FEED 0XA #define CARRIAGE_RET 0XD
void init_UART0(void);
int main() { unsigned char indx,delay,dummy,result=0; unsigned char string[] = {"lohia"}; bitset(PINSEL2,2); //configuring port1 pin31-26 as jtag bitclr(PINSEL2,3); //configuring port1 pin25-16 as GPIO PINSEL1=0x304500C0; //configuring port0 pin16-31 PINSEL0=0X00008255; //configuring port0 pin0-15 IO1DIR=0x00170000; //making port1.16,17,18,20 as o/p init_UART0();
while(1) { indx=0; while(string[indx]) // Transmit till Null('\0') { while(!( U0LSR & TEMT )); //Wait til UOTHR&U0TSR empty
U0THR = string[indx];
dummy = string[indx];
indx++;
for(delay=0x0f;delay--;); } if(dummy==0) result=0; result++; while(!( U0LSR & TEMT )); //Wait til UOTHR&U0TSRempty U0THR = LINE_FEED; U0THR = CARRIAGE_RET; } }
void init_UART0() {
U0FCR = 0X07; // Enable FIFO's and reset them U0LCR = 0X83; // Set DLAB, word length = 8 bits U0DLL = 0X62; // Baud rate set to 9600 U0DLM = 0X0; U0LCR = 0X03; // Clear DLAB
} the hardware required for bus level conversions is also a readymade module(established). iam able to see the data was able pass correctly into dummy variable where as it was not able to go into U0THR ( observed in debug window) sometimes i recieve Framing error and Over run error(observed in debug window). i am not able to find what is the problem. if there is any problem area that i have to concentrate please let me know
Thanks VENKAT KIRAN
