Problem with SPI-Bus
Hello, I have a problem with the SPI-Bus.
I am using the Keil MCB-STR9-Board. When I debug the SSP example source from ST, I will hang in the while loop "SSP_GetFlagStatus(SSP1, SSP_FLAG_RxFifoNotEmpty)==RESET" forever.
SPI-CLk and SPI-Data is driven out from the SPI-Master (SPI0). I have modified the source, but I never get data into the SPI-Slave (SPI1).
After that I tried to set the SPI-Data-In from the master to high or low, but I never get the data 0x00 or 0xFF in the receive-buffer in the Master. I allways have the loopback data from the SPI0-Transmitter.
The Control register 1 from SPI0 is set to 0x0002. I think the loopback function is not enabled with that. What have I made wrong?
Thomas
