Hi
I am using keil realview with keil's RTL and flashfs and appear to be hitting a limit in the filing system that I can't find any referance to in documentation or online.
My program repeated opens a file for read gets data and then closes the file which appear to work perfectly for 64* attempted accesses then ffind returns none zero and fopen returns NULL although the keil debug (peripherals-rtx kernel-FS tab) stay the file exist and is closed. after a reset fopen and ffind work with this file once again.
*(appoximately 64)
Has anyone else come up again this problem?
I will continue to attempt to determine the cause and try a small program to get more details and post back.
Thanks Luke
I'll been unable to reproduce this error with a small test program so must assume it is a bug in my main code! most problably leaving files open even if the debugger claims they are all closed. ... could it be repeated attempts to open a file that doesn't exist - i'm just clutching at straws now :-)
