$NOMOD51 ;------------------------------------------------------------------------------ ; This file is part of the C51 Compiler package ; Copyright (c) 1988-2002 Keil Elektronik GmbH and Keil Software, Inc. ;------------------------------------------------------------------------------ ; STARTUP.A51: This code is executed after processor reset. ; ; To translate this file use A51 with the following invocation: ; ; A51 STARTUP.A51 ; ; To link the modified STARTUP.OBJ file to your application use the following ; BL51 invocation: ; ; BL51 <your object file list>, STARTUP.OBJ <controls> ; ;------------------------------------------------------------------------------ ; ; User-defined Power-On Initialization of Memory ; ; With the following EQU statements the initialization of memory ; at processor reset can be defined: ; ; ; the absolute start-address of IDATA memory is always 0 IDATALEN EQU 80H ; the length of IDATA memory in bytes. ; XDATASTART EQU 100H ; the absolute start-address of XDATA memory XDATALEN EQU 7F00H ; the length of XDATA memory in bytes. ; PDATASTART EQU 0H ; the absolute start-address of PDATA memory PDATALEN EQU 100H ; the length of PDATA memory in bytes. ; ; Notes: The IDATA space overlaps physically the DATA and BIT areas of the ; 8051 CPU. At minimum the memory space occupied from the C51 ; run-time routines must be set to zero. ;------------------------------------------------------------------------------ ; ; Reentrant Stack Initilization ; ; The following EQU statements define the stack pointer for reentrant ; functions and initialized it: ; ; Stack Space for reentrant functions in the SMALL model. IBPSTACK EQU 0 ; set to 1 if small reentrant is used. IBPSTACKTOP EQU 0FFH+1 ; set top of stack to highest location+1. ; ; Stack Space for reentrant functions in the LARGE model. XBPSTACK EQU 1 ; set to 1 if large reentrant is used. XBPSTACKTOP EQU 3FFFH+1 ; set top of stack to highest location+1. ; ; Stack Space for reentrant functions in the COMPACT model. PBPSTACK EQU 0 ; set to 1 if compact reentrant is used. PBPSTACKTOP EQU 0FFFFH+1; set top of stack to highest location+1. ; ;------------------------------------------------------------------------------ ; ; Page Definition for Using the Compact Model with 64 KByte xdata RAM ; ; The following EQU statements define the xdata page used for pdata ; variables. The EQU PPAGE must conform with the PPAGE control used ; in the linker invocation. ; PPAGEENABLE EQU 0 ; set to 1 if pdata object are used. ; PPAGE EQU 0 ; define PPAGE number. ; PPAGE_SFR DATA 0A0H ; SFR that supplies uppermost address byte ; (most 8051 variants use P2 as uppermost address byte) ; ;------------------------------------------------------------------------------ ; Standard SFR Symbols ACC DATA 0E0H B DATA 0F0H SP DATA 81H DPL DATA 82H DPH DATA 83H NAME ?C_STARTUP ?C_C51STARTUP SEGMENT CODE ?STACK SEGMENT IDATA RSEG ?STACK DS 1 EXTRN CODE (?C_START) PUBLIC ?C_STARTUP CSEG AT 0 ?C_STARTUP: LJMP STARTUP1 RSEG ?C_C51STARTUP STARTUP1: IF IDATALEN <> 0 MOV R0,#IDATALEN - 1 CLR A IDATALOOP: MOV @R0,A DJNZ R0,IDATALOOP ENDIF IF XDATALEN <> 0 MOV DPTR,#XDATASTART MOV R7,#LOW (XDATALEN) IF (LOW (XDATALEN)) <> 0 MOV R6,#(HIGH (XDATALEN)) +1 ELSE MOV R6,#HIGH (XDATALEN) ENDIF CLR A XDATALOOP: MOVX @DPTR,A INC DPTR DJNZ R7,XDATALOOP DJNZ R6,XDATALOOP ENDIF IF PPAGEENABLE <> 0 MOV PPAGE_SFR,#PPAGE ENDIF IF PDATALEN <> 0 MOV R0,#LOW (PDATASTART) MOV R7,#LOW (PDATALEN) CLR A PDATALOOP: MOVX @R0,A INC R0 DJNZ R7,PDATALOOP ENDIF IF IBPSTACK <> 0 EXTRN DATA (?C_IBP) MOV ?C_IBP,#LOW IBPSTACKTOP ENDIF IF XBPSTACK <> 0 EXTRN DATA (?C_XBP) MOV ?C_XBP,#HIGH XBPSTACKTOP MOV ?C_XBP+1,#LOW XBPSTACKTOP ENDIF IF PBPSTACK <> 0 EXTRN DATA (?C_PBP) MOV ?C_PBP,#LOW PBPSTACKTOP ENDIF MOV SP,#?STACK-1 ; This code is required if you use L51_BANK.A51 with Banking Mode 4 ; EXTRN CODE (?B_SWITCH0) ; CALL ?B_SWITCH0 ; init bank mechanism to code bank 0 LJMP ?C_START END
I am using above startup.a51 in my project. I want to use one global variable as a flag, so that its value should be retained after resetting device. I set one global variable at memory location 8000 and I changed in startup.a51 initialization from XDATALEN EQU 7F00H to XDATALEN EQU 7EFFH But still it is intializing this variable to 0 after resetting. Please give me the solution for this problem.
"But still it is intializing this variable to 0 after resetting"
Is that in the Simulator, or a real target?
It is in a real target.
What kind of target ?
The internal memory does not get zeroed during a reset, but what the external memory does is pretty much implementation-defined.
If this variable is truly defined as "global" or static somewhere, then the initialization to zero might well be occurring in a place other than startup.A51.
One of the things that C compilers have to guarantee is that any variable defined with static storage class is automatically initialized to zero if you don't specify an initial value explicitly. The location where xdata memory is initialized to zero isn't necessarily what does this, if I remember correctly.
C51 uses some magic like C_INITSEG to keep a list of all the static/global variables and then runs through there and initializes all those to zero (or whatever value you've explicitly specified). That might be where you have to turn your sights.
To take a look at what happens, check out the file INIT.A51. I'm guessing that would be the next good place to take a look.
What kind of reset are you using?
If it is a complete board reset, you may well find that the memory device in which the variable is mapped is being resetted as well.
Jose
yes, I am resetting entire board. Is there any other way to retain the value of that variable?
"C51 uses some magic like C_INITSEG to keep a list of all the static/global variables and then runs through there and initializes all those to zero (or whatever value you've explicitly specified). That might be where you have to turn your sights."
My recollection is that C_INITSEG just does non-zero initialisations; the rest is done by startup.A51.
However, I wouldn't like to bet on my recollection being better than yours - so the OP is just going to have to do his own research to be sure!
At least he now has some good Keywords to start his searching: "C_INITSEG", "startup.A51", "INIT.A51"...
use any debugger (preferably an ICE)
at the beginning of statup, patch the variable to nonzero, set a breakpoint at the end of statup, if sti;ll nonzero, set abreakpoint...
standard debugging technique.
