8051 ERROR C146 'P4' invalid base address
Hi!
I hope you can help me with this. I have a 8051 C146 Error in the uvision keil compiler inside Silicon labs IDE.
The error is
*** ERROR C146 IN LINE 320 OF C8051F020.H: 'P4' invalid base address
The line of code giving the error is:
sbit InputTrayCoverSen =P4^0;
I think I have the P74Out setup right and P4 is 0x84. It is almost like Port 4 oesn't even exist or get recognized by the assembler.
I have looked through your support webages and cannot even find this error C146 is not invalid base address. C166 is. I'm a bit confused.
The entire code segments and setups are below:
Many Thanks if you can help with this problem in any way!
Richard Howes
Continuing Engineering Manager
702-358-5714
; FILE NAME : C8051F020.H
; TARGET MCUs : C8051F020, 'F021, 'F022, 'F023
; DESCRIPTION : Register/bit definitions for the C8051F02x product family.
; REVISION 1.1
#ifndef __REGISTERS
#define __REGISTERS
/* BYTE Registers */
sfr P0 = 0x80; /* PORT 0 */
sfr SP = 0x81; /* STACK POINTER */
sfr DPL = 0x82; /* DATA POINTER - LOW BYTE */
sfr DPH = 0x83; /* DATA POINTER - HIGH BYTE */
sfr P4 = 0x84; /* PORT 4 */
sfr P5 = 0x85; /* PORT 5 */
sfr P6 = 0x86; /* PORT 6 */
sfr PCON = 0x87; /* POWER CONTROL */
sfr TCON = 0x88; /* TIMER CONTROL */
sfr TMOD = 0x89; /* TIMER MODE */
sfr TL0 = 0x8A; /* TIMER 0 - LOW BYTE */
sfr TL1 = 0x8B; /* TIMER 1 - LOW BYTE */
sfr TH0 = 0x8C; /* TIMER 0 - HIGH BYTE */
sfr TH1 = 0x8D; /* TIMER 1 - HIGH BYTE */
sfr CKCON = 0x8E; /* CLOCK CONTROL */
sfr PSCTL = 0x8F; /* PROGRAM STORE R/W CONTROL */
sfr P1 = 0x90; /* PORT 1 */
sfr TMR3CN = 0x91; /* TIMER 3 CONTROL */
sfr TMR3RLL = 0x92; /* TIMER 3 RELOAD REGISTER - LOW BYTE */
sfr TMR3RLH = 0x93; /* TIMER 3 RELOAD REGISTER - HIGH BYTE */
sfr TMR3L = 0x94; /* TIMER 3 - LOW BYTE */
sfr TMR3H = 0x95; /* TIMER 3 - HIGH BYTE */
sfr P7 = 0x96; /* PORT 7 */
sfr SCON0 = 0x98; /* SERIAL PORT 0 CONTROL */
sfr SBUF0 = 0x99; /* SERIAL PORT 0 BUFFER */
sfr SPI0CFG = 0x9A; /* SERIAL PERIPHERAL INTERFACE 0 CONFIGURATION */
sfr SPI0DAT = 0x9B; /* SERIAL PERIPHERAL INTERFACE 0 DATA */
sfr ADC1 = 0x9C; /* ADC 1 DATA */
sfr SPI0CKR = 0x9D; /* SERIAL PERIPHERAL INTERFACE 0 CLOCK RATE CONTROL */
sfr CPT0CN = 0x9E; /* COMPARATOR 0 CONTROL */
sfr CPT1CN = 0x9F; /* COMPARATOR 1 CONTROL */
sfr P2 = 0xA0; /* PORT 2 */
sfr EMI0TC = 0xA1; /* EMIF TIMING CONTROL */
sfr EMI0CF = 0xA3; /* EXTERNAL MEMORY INTERFACE (EMIF) CONFIGURATION */
sfr P0MDOUT = 0xA4; /* PORT 0 OUTPUT MODE CONFIGURATION */
sfr P1MDOUT = 0xA5; /* PORT 1 OUTPUT MODE CONFIGURATION */
sfr P2MDOUT = 0xA6; /* PORT 2 OUTPUT MODE CONFIGURATION */
sfr P3MDOUT = 0xA7; /* PORT 3 OUTPUT MODE CONFIGURATION */
sfr IE = 0xA8; /* INTERRUPT ENABLE */
sfr SADDR0 = 0xA9; /* SERIAL PORT 0 SLAVE ADDRESS */
sfr ADC1CN = 0xAA; /* ADC 1 CONTROL */
sfr ADC1CF = 0xAB; /* ADC 1 ANALOG MUX CONFIGURATION */
sfr AMX1SL = 0xAC; /* ADC 1 ANALOG MUX CHANNEL SELECT */
sfr P3IF = 0xAD; /* PORT 3 EXTERNAL INTERRUPT FLAGS */
sfr SADEN1 = 0xAE; /* SERIAL PORT 1 SLAVE ADDRESS MASK */
sfr EMI0CN = 0xAF; /* EXTERNAL MEMORY INTERFACE CONTROL */
sfr P3 = 0xB0; /* PORT
