Reading a memory location into a C varaible
I need to read a memory location (SRAM)and load the value into a variable of type integer in my 'C' code.
How do I achieve the above mentioned problem in C?
Do I need to do some kind of translations to be done when I read the value so that it would be read as proper integer?
Regards,
Jinen Dedhia
  • "How do I achieve the above mentioned problem in C?"
    #define SOME_ADDRESS 0x1234
    int i = *(int*)SOME_ADDRESS;
    "Do I need to do some kind of translations to be done when I read the value so that it would be read as proper integer?"
    That depends on the how the value is stored in memory versus your platform's requirements.
