Hello to all!
Is possible to make a call to a SWI routine from a FIQ Handler when you are using the RTX Kernel?
I try this approach but a UNDEFINED exception occurs on exit of SWI function. See the code below:
void FIQCapture (void) __irq { static U32 ticksCounter = 0; ticksCounter++; if (ticksCounter > ((U32) 5)) { // Call freqMsrSignal in Fast Interrupt Mode freqMsrSignal(0x0001, &taskMeasureLoop); ticksCounter = 0; } // Match 0 asserted. Clear. T0IR = 1 << 0; } void __swi(8) freqMsrSignal(U16 event_flags, OS_TID *task); void __SWI_8 (U16 event_flags, OS_TID *task) { // Increment the SWI_Times in Supervisor Mode SWI_Times++; // Call a RTX function in Supervisor Mode os_evt_set(event_flags, *task); /// The context switch was: User->FIQ->Supervisor return; }
With this manner, I can call OS Functions from a FIQ Handler, my goal.
However, after run freqMsrSignal the system are switch to Undefined context
Undef_Handler B Undef_Handler
The code run the branch above (in a endless loop).
I use the uVision 3.50. Any suggestions?
