Question for Assembly function "LMUL"。
Dear sir, i use lmul to do "0x12345678 * 0xff = 0x12,22,22,21,88"
if i need the overflow value "0x12" what can i do ?
thanks a lot .
Sincerely,
Luke.
  • You will probably need to stop using lmul and roll your own multiplication function.
    lmul does a 32x32 multiplication and returns the 32 lowest bits of the result.
    If you want a 32x8 multiplication and all 40 bits of the result, you will need to split the operation into several smaller multiplications and additions using the commutative, distributive and associative principles:
    en.wikipedia.org/.../Multiplication
    For example, if H is the upper 16 bits of the 32 bit multiplicand, L is the lower 16 bits of the 32 bit multiplicand, and C is the 8 bit multiplicand, your 32x8 bit multiplication can be expressed as
    (65536*H + L) * C
    which can be split into two 16x8 -> 24 bit multiplications:
    H * C = RH
    L * C = RL
    Now you can calculate the 32 LSBs of the 40 bit end result as
    RL + 65536 * RH
    and the upper 8 bits of the result are in bits 16-23 of RH.
