MCB-STR9 SD card operation - made it work?
It seems the str9 processor will always loop-back data sent on the SSP if the NSS pin is low. This is true whether that pin is programmed as an input or output. In order to create a chip select signal to use the SD card in SPI mode then, I cut the track and use another GPIO pin for the purpose.
This fixed the "always looping back" problem and lets me read replies from the card.
However, I'm still having trouble. The card never seems to go into SPI mode. Has anybody got this working?
Dave
