problem with Large Memory model
Hi Keil,
I sloved the EEPROM problem with AT89C51ED2, the problem was in the memory module selection.
Since I had selected large memory model, the EEPROM was not working, when I changed it to Small memory model,it started working fine.
But now my problem is my project is designed for Large memory model , How can I make this code work for Large memory model??
I checked it for Read operation, It was working fine, but It was not able to write to EEPROM with this large model!!
The code is,
                   FUNCTION TO WRITE DATA TO INTERNAL E2ROM OF AT89C51ED2
                void WriteE2ROM(unsigned char xdata *Addr,unsigned int e_data)
                                unsigned char idata FBuffer[6];
                                char idata i=-1;
                                sprintf(FBuffer,"%d",(unsigned int)e_data);
                                do
                                {               while(BUSY);
                                                EA=0;
                                                E_EEPROM;
                                                i++;                                                            // WRITE
                                                *(Addr+i) =FBuffer[i];
                                                D_EEPROM;
                                                EA=1;
                                }while(FBuffer[i]!='\0');
        FUNCTION TO READ DATA TO INTERNAL E2ROM OF AT89C51ED2
                 unsigned int ReadE2ROM(unsigned char xdata *Addr)
                                        unsigned char idata EBuffer[6];
                                        unsigned int idata FData;
                                        unsigned char idata i=0;
                                        while(BUSY);
                                        EA=0;
                                        E_EEPROM;
                                        while(*(Addr+i)!='\0')
                                                EBuffer[i] = *(Addr+i);          // READ
                                                i++;
                                        D_EEPROM;
                                        EA=1;
                                        EBuffer[i]='\0';
                                        FData=atoi(EBuffer);
                                        return FData;
Is there any better approch to write to eeprom ???
If it is please send me the correct way to approch the problem.
