Hi, With the new keil+realview compiler, user can not dirrectly access the LR register. I had the following line of code:
__asm{ LDR LR, [LR, #+60] };
The above was compiled fine with the CARM compiler.
Switching to Realview compiler, the compiler gives me the following error:
error: #52: expected a marcro parameter name
If you no longer can access the LR, SP ... what is the way to do this?
