I have a problem with the following code:
#pragma LARGE #include <C8051F120.H> #include <stdio.h> char add(char a) reentrant { printf("Data is %d\n",a); if(a==255) { return 0; } else { return add(a+1); } } void main() { unsigned int uiData=0; SCON0 = 0x50; TMOD |= 0x20; TH1 = 0x96; TR1 = 1; TI0 = 1; add(0); while(1); }
Data is 0 Data is 1 Data is 2 ....
Data is 0 Data is 256 Data is 512 Data is 768 ....
You should use the 'b' prefix. See: http://www.keil.com/support/man/docs/c51/c51_xf_usingprintf.htm
I Already got it. Anyway thank you keil!
