hello to all of you, is there a way to have a array and give each element of the array a special name? An example:
float my_array[20]; . . for(i=0;i<20;i++) send(my_array[i]; . .
Could you possibly be wanting something as simple as the preprocessor's text substitution?
#define actual_temperature my_array[1] #define minimum_temperature my_array[2] #define maximal_temperature my_array[3]
Hallo to everybody. Now being back from camping-holiday in Italia i wana thank you for your help.
this fits perfect to my requirements, thank you Dan, i would have send you a picture-postcard from Pisa if i have had your adress ;-)
This hint is very helpful, everybody needs a little help if there are tomato-slices on front of your eyes ;-)
It is a fairly ugly way to do this and will confuse the heck out of anyone trying to maintain it.
Use a union instead. At least this makes it clear which array you're actually referencing to.
Then why not just declare these three variables instead of an array?
Or make them fields in a struct, so you can send the entire block of three variables with one call to the send() routine.
It quite definitely doesn't --- it clearly fails the "have the same address" criterion. And neither is it perfect, in any useful interpretation of the word. A struct would be a whole lot more readable.
