Hello all, why does the following code crash when called from interrupt context, if I turn on all compiler optimizations? the call to vsprintf causes an access violation, even when run on the simulator.
void software_error(const char* a_fmt, ...) { char l_buffer[0x80] ; va_list l_arg_ptr ; PSW_IEN = 0 ; va_start(l_arg_ptr, a_fmt) ; vsprintf(l_buffer, a_fmt, l_arg_ptr) ; va_end(l_arg_ptr) ; printf("SOFTWARE ERROR:%s\n", l_buffer) ; operational_LED_off() ; error_LED_on() ; rtos_invoke_failure_hook() ; while(1) ; // hang here }
It depends really on the paramenters that you are using. l_buffer has a size limit and might overrun here.
Try declaring your variables as volatile.
