Failure to load symbols & HLL capability into Metalink XF
I recently am unable to use "HLL" feature in Metalink XF emulator even though it appears that uV3 is generating the symbol table, as I can see it in limited debug feature in UV3. This amomaly occurred after I "saved as" a source file from uV3. Since that transaction the emulator says "no source files available". This condition had occurred previously several months ago & then inexpicably rectified itself. Also, the BL 51 linker appears to be generating an executable file of the type "Adobe Download Manager File". However on some link attempts no resulting file can be found anywhere. Additionally attempts at assigning files to the "books" section totally fail. It appears that the file allocation and finding features of uV3 are serioualy flawed. I am using Windows XP. Is there some fundamental incompatibility between this os & uV3?
