Wireless nrf24e1 LED flash
HI :-) as promised, im having problems with the wireless connection on the nordic nrf24e1, I am trying to send a packet and then if received, flash an LED. Can anyone see any problems with the below code. first is the transmitter code then i will reply with the receiver code:
#include <reg24e1.h>
struct RFConfig
    unsigned char n;
    unsigned char buf[15];
typedef struct RFConfig RFConfig;
#define ADDR_INDEX  8   // Index to address bytes in RFConfig.buf
#define ADDR_COUNT  4   // Number of address bytes
const RFConfig txconf =
    15,
    0x08, 0x08, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
    0x12, 0x34, 0x56, 0x78, 0x83, 0x6c, 0x04
const RFConfig rxconf =
    15,
    0x87, 0x65, 0x43, 0x21, 0x83, 0x6c, 0x05
// LED is to be connected to this pin
sbit LED_pin = P1^0;
// Function prototypes
void DELAY_LOOP_Wait(const unsigned int);
void DELAY_100us(volatile unsigned char n);
unsigned char SPI_ReadWrite(unsigned char b);
void TRANSMIT_Packet(unsigned char b);
void TRANSMITTER(void);
void INIT(void);
void main(void)
                INIT();
          while(1)
            TRANSMITTER();
  DELAY_LOOP_Wait()
void DELAY_LOOP_Wait(const unsigned int DELAY)
   unsigned int x, y;
   for (x = 0; x <= DELAY; x++)
      for (y = 0; y <= 800; y++);
  DELAY_100us()
    unsigned char i;
    while(n--)
        for(i=0;i<35;i++)
  SPI_ReadWrite()
    EXIF &= ~0x20;                  // Clear SPI interrupt
    SPI_DATA = b;                   // Move byte to send to SPI data register
    while((EXIF & 0x20) == 0x00)    // Wait until SPI hs finished transmitting
    return SPI_DATA;
  TRANSMIT_Packet()
    unsigned char i;
    CE = 1;
    DELAY_100us(0);
    // Start with the address of the receiver:
    for(i=0;i<ADDR_COUNT;i++)
        SPI_ReadWrite(rxconf.buf[ADDR_INDEX+i]);
    SPI_ReadWrite(b);
    CE = 0;
    DELAY_100us(3);                  // Wait ~300us
  TRANSMITTER()
    unsigned char b, bo, err;
    CS = 1;
    DELAY_100us(0);
    for(b=0;b<txconf.n;b++)
        SPI_ReadWrite(txconf.buf[b]);
    CS = 0;
    for(;;)
       TRANSMIT_Packet(b);          // Transmit data
void INIT(void)
    PWR_UP = 1;                     // Turn on Radio
    DELAY_100us(30);                // Wait > 3ms
    SPICLK = 0;                     // Max SPI clock (XTAL/8)
    SPI_CTRL = 0x02;                // Connect internal SPI controller to Radio
  • Receiver code:
    struct RFConfig
        unsigned char n;
        15,
        15,
    unsigned char RECEIVE_Packet();
    void RECEIVER(void);
    void LED_Flash();
    void INIT(void);
    void main(void)
                    INIT();
              while(1)
                RECEIVER();
      DELAY_LOOP_Wait()
       unsigned int x, y;
      LED_FLASH()
    void LED_Flash()
            do
                    LED_pin = 0;
                    DELAY_LOOP_Wait(1000);
                    LED_pin = 1;
            }  while(1);
      DELAY_100us()
        unsigned char i;
        while(n--)
            for(i=0;i<35;i++)
      SPI_ReadWrite()
        return SPI_DATA;
      TRANSMIT_Packet()
        unsigned char i;
        CE = 1;
        DELAY_100us(0);
        SPI_ReadWrite(b);
        CE = 0;
      RECEIVE_Packet()
        unsigned char b;
        CE = 1;
        while(DR1 == 0)
        b = SPI_ReadWrite(0);
        CE = 0;
        return b;
      RECEIVER()
    void RECEIVER(void)
        CS = 1;
        DELAY_100us(0);
        for(b=0;b<rxconf.n;b++)
            SPI_ReadWrite(rxconf.buf[b]);
        CS = 0;
            bo = err = 0;
        for(;;)
            b = RECEIVE_Packet();
                    LED_Flash();
      TRANSMITTER()
        unsigned char b;
        CS = 1;
        DELAY_100us(0);
        CS = 0;
        for(;;)
    void INIT(void)
            P1_DIR = 0;
