DHCP failure discovery - mcb2300
I wonder if there is any way to get information about failed dhcp process?
I need to start dhcp, and if it's not succeeded, disable dhcp and use a default local ip (case of a direct connect to a pc).
I understand, that i can monitor local ip, but is there a better way?
Also when dhcp is not succesful, the mcb2300_debug complains that retransmit timeout is too big.
Thanks,
Gennady
