I wonder if there is any way to get information about failed dhcp process? I need to start dhcp, and if it's not succeeded, disable dhcp and use a default local ip (case of a direct connect to a pc). I understand, that i can monitor local ip, but is there a better way? Also when dhcp is not succesful, the mcb2300_debug complains that retransmit timeout is too big.
Thanks, Gennady
DHCP client tries to obtain a valid IP. It uses exponential backoff retransmission on timeout. After 30 seconds, DHCP client is restarted. This process repeats indefinetly or until a valid IP is obtained. There is no such function to check if a DHCP has failed.
You can monitor the IP address as you have figured out. However I see no reason for doing this. For example a PC can be configured either to use a DHCP or a static IP, but not both at the same time.
Maybe you can check this restart somehow and allow the DHCP client to try for only x*30 seconds? After that you could disable the DHCP client and set your own fixed IP. I don't know this specific client so I don't really know what I'm talking about anyway :-)
I don't suppose you have the source code of the client?
Regards, Joost Leeuwesteijn
