tcp / udp sockets - receiving data
I have a project for lpc2378 (mcb2370 board) and need to implement a few udp and tcp sockets to send/receive data (client).
There is very little explanation for a process of receiving data for tcp / udp sockets in RL-ARM's tcp/ip stack. Often mentioned example LEDSwitch - server is just not present anywhere.
Manuals for a lot cheeper tools (= FREE, see for example Wiznet manuals) give a pretty good explanation of processes, including detailed flowcharts.
Maybe it's too much to ask for $4000, but I would expect a little bit more from the manual then generally just API functions list.
  • An example for TCP/UDP socket sending or receiving data can be found:
    1. server mode
    \Keil\ARM\RV30\RTL\Boards\Keil\MCB2300\LEDSwitch
    2. client mode
    \Keil\ARM\RV30\RTL\Boards\Keil\MCB2300\LEDSwitch\Client
    Documentation:
    RL-ARM->TcpNet->TCP Socket
    RL-ARM->TcpNet->UDP Socket
    There you can find also Example for Sending Data for UDP and for TCP Socket.
    1. server mode
    2. client mode
    Documentation:
