Hi to All,
I am trying to do the following: to copy ARM reset vectors (64 bytes) from internal flash to internal RAM, then to set boot configuration of CPU so 0x00000000 to reference 0x20000000 (internal RAM), so in this way I have reset vectors in RAM.
Well, Application starts, but and some point it stacks and I observe these 64 bytes changed.
Linker is instructed (I tried with Keil and ARM tools – same result) to use internal RAM with 64 bytes offset from: 0x20000040.
What might write in this area?
Thank you in advance, Nivelinn
A faulty pointer.
