I can program/ erase Luminary EVAL board, but when starting the debugger the IDE get stuck. This problem didn't accur with prior versions. What could be wrong ?
Did you select the correct debug driver? How can we duplicate this issue?
All is fine now. I unchecked some settings and the debugger started working. Then I checked settings as before and the debugger worked again. Don't ask me why it just solved this issue.
I also had this problem with the LM3S811 Eval board. It can be duplicated by choosing the option "Load Application at Startup" when entering debug. When this option is turned off, the debug session starts and does not hang up.
