I am presently testing the STR710 micro from STmicroelectronics using KEIL UV3 IDE. I have discovered from my own code (as well as the sample codes shipped with the compiler. Placing an IRQhandler AFTER the main() function causes the file not compile and showed lots of errors. But when placing the IRQHandler BEFORE or near the beginning of the program then it compiled fine. I have noticed some pre-compile directive in certain area #pragma userclass (CODE = default) and #pragma userclass (CODE =IRQ) resided in the c file. However, I had never be able to come up with a conclusive result by trying to place the above directives in various area of the file. My question is what is the RIGHT way to do in term of placing IRQhandler? void main (void) { } void IRQHandler_one() { } void IRQHanlder_two() { } The above arrangement NOT working
We have re-worked the way ISR routines are defined in the RealView MDK-ARM V3.01 (where we are using the RealView Compiler). Please download the current revision MDK-ARM V3.01 and refer to the new version of the MCBSTR7 user's guide that is part of this release. Reinhard
Now I am confused. I checked the ARM development tool selection under PROJEC/COMPONENT/ENVIROMENT option and I noticed that the USE KEIL CARM was checked. Are you saying that I am using the wrong tool? I thought Uvision3 using KEIL CARM? I tried to select the REALVIEW box (for experiment reason) the results were much worst !! lots of error !! The worst thing was that the project was no longer usable even I switched back to KEIL CARM compiler. I find that, unlike the Uvision2, this ARM compiler (UV3) is very hard to use, and the manual is really useless.
Are you using MDK-ARM V3.01? You may download a Eval Version from https://http://www.keil.com/demo/eval/arm.htm
