Hi, In the code below, I am trying to erase a flash page in conjuction with a UART interrupt. By them selves, the interrupt and flash erase work fine, but when I put them together, the flash erase has no effect. Would anyone have any idea how the UART interrupt is affecting my flash erase. Thanks. #include "c8051f060.h" // SFR declarations // ------------------- void flash_erase(int startpage, int npages) { char xdata* data pagePointer = 0; / EA = 0; // temporary disable interrupts FLSCL |= 0x01; // Enable FLASH R/WR via software PSCTL = 0x03; // MOVX erases FLASH pagePointer = (char xdata*)(startpage * 512); *pagePointer = 0; // initiate the erase PSCTL = 0x00; FLSCL |= 0x01; // Disable FLASH R/WR via software } // ---------------------- void UART1_ISR (void) interrupt 20 { if (RI1) { EA = 0; flash_erase(0x1F, 1); RI1 = 0; //clears receive flag } } // --------------- int main() { WDTCN = 0xDE; //disable WDT WDTCN = 0xAD; SFRPAGE = UART1_PAGE; SCON1 = 0x50; // Receive enabled EA = 1; // global interrupt enable EIE2 |= 0x40; // Enable UART1 ISR RI1 = 1; //trigger UART1 interrupt return 0; } //-----end main
What is main() returning to?
nothing in particular. I think that I had it in there as an artifact of another compiler that required main to have a return type.
I think you should examine the execution path after main() returns. Does it return to some code that stays in a tight loop, or restarts the program, or just runs amok, or ...
[HINT]: Generally, an embedded system never returns from main().
