Hi all, When I compile my assembly program I am getting the following error.I would like to know the reason for this error and a solution to overcome this. what does the line below tell? CLASSES (DATA (0x40000000-0x40003FFF), CODE (0x0-0x3FFFF), CONST (0x0-0x3FFFF)) Build target 'Target 1' assembling CRC.a... linking... LARM LINKER/LOCATER V2.42 - SN: Eval Version COPYRIGHT KEIL ELEKTRONIK GmbH 2001 - 2005 @CRC.lnp "CRC.obj" TO "CRC" CASE CLASSES (DATA (0x40000000-0x40003FFF), CODE (0x0-0x3FFFF), CONST (0x0-0x3FFFF)) *** ERROR L210: I/O ERROR ON INPUT FILE: EXCEPTION 0021H: PATH OR FILE NOT FOUND FILE: CRC.obj Target not created
Well I was trying to intialize 256 values to an array variable.I did it using the follwing statement array_a:DD 0,0,0,0,0,0,0,0,likewise up t0 256th location...... If I commented this line I am not getting the error. I would like to know how I could initialize 256 memory location for an array of size 256 (array_a [256]) in ARM assembly language. looking for your help
Looks like a bug. What is actually the content of the CRC.A file? We recommend to use the current Version of the RealView MDK-ARM (download via http://www.keil.com/demo). There is also an assembly language example on: http://www.keil.com/download/docs/314.asp
