Hi all, I'm using the AT91SAM7S64 chip on the Evaluation Board AT91SAM7S-EK, and I'm trying to write the internal flash rom. The code that I use is the follow: unsigned int dato = 0xAABBCCDD; unsigned int address = 0x00100000; int page = 20; AT91F_Flash_Init(); AT91F_Flash_Write_Page(address, dato); void AT91F_Flash_Init (void) { AT91C_BASE_MC->MC_FMR = ((AT91C_MC_FMCN)&(72 <<16)) | AT91C_MC_FWS_1FWS; } int AT91F_Flash_Ready (void) { int status; status = 0; //* Aspetto la fine del comando while ((status & AT91C_MC_FSR_FRDY) != AT91C_MC_FSR_FRDY ) { status = AT91C_BASE_MC->MC_FSR; } return status; } int AT91F_Flash_Write_Page(unsigned int Flash_Address, unsigned int buff) { AT91PS_MC ptMC = AT91C_BASE_MC; page = 510; Flash = (unsigned int *) Flash_Address; *Flash = buff; //* Do il comando di scrittura ptMC->MC_FCR = AT91C_MC_CORRECT_KEY | AT91C_MC_FCMD_START_PROG | (AT91C_MC_PAGEN & (page <<8)) ; //* Aspetto la fine del comando status = AT91F_Flash_Ready(); return (1); } My program haven't problem when I perform a debug step-by-step; instead my program doesn't work (go to "crash" !!!) when I try to run it. Could you hel me? Thanks.
