C166 output directory
Hi all,
Is it possible to specify the output directory? Something like an OUTPUTDIR() directive. This would make it easier to set/unset other options in a global makefile. Now you have to add a complete filename to the directives if the output directory is different. Setting/unsetting only PRINT or PREPRINTONLY for example (without a path+filename) would be easier to maintain in a makefile.
Regards,
Joost Leeuwesteijn
