I just started using keil c51 compiler. Since I know that keil is compatible to ANSI-C I want to know if there is an ANSI-C compatible notation for binary numbers. Like when I want to write the number in hexadecimal notation I use the prefix "0x" -> 0xFF All oher numbers are considered to be in decimal notation. -> 1234567890 But which prefix do I use for binary number system? I already tried (0b..., ...b, ...) and got ->error C251: illegal octal digit ->error C141: syntax error near 'b' ... By the way, it would be nice to know which notation to use for octal number systems. Regards J.
http://www.8052.com/users/dhenry/binconst.h
Do not make the mistake of buying another "C and '51" book. Those books do NOT teach you C, they are "the 51' for programmers already versed in C". A good self-teach book would be Kochan: "Programming in ANSI C". It is so much easier to learn the C fundamentals on the PC than on a '51. PS: there are posts here or on 8052.com about free Borland C compilers for the PC which will allow you to work through the examples Erik
"PS: there are posts here or on 8052.com about free Borland C compilers for the PC which will allow you to work through the examples" One thing to beware of is that they're probably C++ compilers, and/or C99. Most embedded 'C' compilers (including C51) are the "original" ANSI 'C' Both C++ and C99 will accept "original" ANSI 'C', but will let you get away with things that a true "original" ANSI 'C' does not allow. There's often an option to enable "pure ANSI" mode...
