I've got a problem. I've posted it yesterday but it was probably lost in text.
static void Nastav_seriovy_kanal (void) { SCON = 0x50; TMOD = TMOD | 0x20; TH1 = 0xF4; TL1 = 0xF4; ES = 1; TR1 = 1; } static void Preruseni_seriovy_kanal (void) interrupt 4 { if (RI == 1) { RI = 0; if(SBUF == 'A') putchar('Q'); } if (TI == 1) TI = 0; }
"I've posted it yesterday but it was probably lost in text." Rather than just re-post it, how about supplying more information? That way someone might be able to offer some informed help! Like specifying the toolset, for a start! "it doesn't work?" Does it build without errors and warnings? What do you think it should do? What does it actually do? How have you tested it?
Putchar procedure doesn't work as I expected. In my opinion and I hope it's clearly said in that source code I've posted, it should work as follows. When 'A' character is received through serial port of x51 processor it sends a 'Q' character back. But it won't send anything back. There are no errors or warnings. Serial port is functional.
I could simply change it as follows.
if(SBUF == 'A') SBUF = 'Q';
"I want to use PUTCHAR and later PUTS procedures to communicate through serial port." It is a very bad idea to try to use these in an interrupt service routine! For interrupt-driven serial IO, see: http://www.keil.com/download/docs/71.asp This shows you how to write a custom putchar to use interrupt-driven serial comms.
It is a very bad idea to try to use these in an interrupt service routine! Well ... yeah. You can use them in an ISR, as long as you're aware that they are going to hog CPU cycles like crazy (they spinlock if the serial transmitter is busy) and that they're not reentrant. Also, I think there's some code putchar.c that could drop characters or enter an endless loop under certain rare circumstances. Something along the lines of
do { RI = 0; while(!RI); } while(SBUF != XON)
