Dear sir, i am is a student in physic department,i use uVision IDE for 8051 ver 6.20c, build a single board computer, with core is AT89S52,one Dallas RTC 12C887,and an 8255 PPI, both (RTC & PPI) connected to external ram addres (0x0000),selection which chip activated is done by connecting RTC cs pin to P2.7 micro by an inverter,beside it cs pin on PPI is direct connected to P2.7,i use PPI for driving LCD, and other stepper.i write code like this:
#include <REG52.H> /* define 8051 registers */ #include <stdio.h> /* define I/O functions */ #include <stdlib.h> #include <intrins.h> #include <string.h> #include <absacc.h> sbit chip_slct = P2^7; void initializePPI() { unsigned char xdata PPI_dt _at_ 0x0000; /* int at xdata 0x0*/ //unsigned char ppi_dat; //ppi_dat = XBYTE [0x0002];// = 57; chip_slct = 0; //activated PPI chip PPI_dat = 0x80; } . . . . ->>>>>> resulting error message C274 when compiling
Read the description of the error message (hint: "function locals"). That aside, "PPI_dt" is defined and "PPI_dat" is used!
Absolute specifier illegal..what that mean?
Once again, read the description of the error message (hint: "function locals"). Further hint: Please read the manual. http://www.keil.com/support/man/docs/c51/c51_c274.htm
what the couse is,i use PPI_dt as local var?,what is the syntax to define a var as global variable in keil (c)... sorry.. i am beginner in c,sorry about my english.
sorry, everything OK now... there is 'something' fail in my eyes and 'head'.thanks, for Ur assist.
First, you need to read the uVision Getting Started guide, and work through the example projects in it. This will give you a proper introductions to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep-end!
First, you need to read the uVision Getting Started guide, and work through the example projects in it. This will give you a proper introductions to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep-end! Andy, How right you are, but what is the hope of someone actually realizing that if you do not know how to boil water, you have but little chance making a cordon bleu? Erik
