Setting up UART for 9600, 8, e, 1 -Works on PC but not on target
Need advice on what is going on with this program.
It partially works when connected to a PC (Windmill ComDebug) but does not work on the device. It seems that I fail to work with the parity bit, because the ComDebug can not tell the difference between even parity, no parity and odd parity. But I miserably fail to master the TB8, ACC and P to make it work.
I am struggling with an ATMEL 89C5131. I want to set it up for 9600, 8, e, 1. The Xtal is 16MHz, due to the USB needs.
The target device is a bill acceptor. Its protocol requires these settings.
The protocol is as: Synch; Lengh; data; CRC; CRC.
Synch is 0xFC; Lenght: 0x05; data is 0x40 (reset); 0x2B; 0x15. I have the following code copied from intsio2 from Keil site.
The modifications are adaptations to the required settings.
The SIO works as a charm, of course, I just can not master it to handle the parity bit.
Any help is very welcome.
Ed
SIO.C:  Serial Communication Routines.
Copyright 1995-2002 KEIL Software, Inc.
#include <reg51.h>
#include <string.h>
#include "sio.h"
#define TBUF_SIZE   8           /*** Must be one of these powers of 2 (2,4,8,16,32,64,128) ***/
#define RBUF_SIZE   16           /*** Must be one of these powers of 2 (2,4,8,16,32,64,128) ***/
#define TBUF_SPACE  idata       /*** Memory space where the transmit buffer resides ***/
#define RBUF_SPACE  idata       /*** Memory space where the receive buffer resides ***/
#define CTRL_SPACE  data        /*** Memory space for the buffer indexes ***/
void com_initialize (void)
Setup TIMER1 to generate the proper baud rate.
com_baudrate (9600);
Clear com buffer indexes.
t_in = 0;
t_out = 0;
r_in = 0;
r_out = 0;
Setup serial port registers.
SM0 = 1; SM1 = 1;   /* serial port MODE 2 */
SM2 = 0;
REN = 0;            /* enable serial receiver */
RI = 1;             /* clear receiver interrupt */
TI = 1;             /* clear transmit interrupt */
ti_restart = 1;
ES = 1;             /* enable serial interrupts */
PS = 0;             /* set serial interrupts to low priority */
#pragma disable
void com_baudrate (
  unsigned baudrate)
   SCON = 0xF0; /* uart in mode 3 (9 bit), REN=1 */
   T2CON &= 0xF0;               /* EXEN2=0; TR2=0; C/T2#=0; CP/RL2#=0; */
   T2CON |= 0x30;               /* RCLK = 1; TCLK=1; */
   TH2=0xFF;                    /* init value */
   TL2=0xFD;                    /* init value */
   RCAP2H=0xFF;                 /* reload value, 9600 Bds at 16.MHz */
   RCAP2L=0xCC;                 /* reload value, 9600 Bds at 16.MHz */
        ES = 1;                                                      /* Enable serial interrupt */
        EA = 1;                                              /* Enable global interrupt */
   TR2 = 1;                     /* Timer 2 run */
Clear transmit interrupt and buffer.
TI = 0;             /* clear transmit interrupt */
t_in = 0;           /* empty transmit buffer */
t_out = 0;
Set timer 1 up as a baud rate generator.
//TR1 = 0;            /* stop timer 1 */
//ET1 = 0;            /* disable timer 1 interrupt */
//PCON |= 0x80;       /* 0x80=SMOD: set serial baudrate doubler */
//PCON |= 0x82;       /* 0x80=SMOD: set serial baudrate doubler */
//TMOD &= ~0xF0;      /* clear timer 1 mode bits */
//TMOD |= 0x20;       /* put timer 1 into MODE 2 */
//TH1 = (unsigned char) (256 - (16000000 / (16L * 12L * baudrate)));
//TR1 = 1;            /* start timer 1 */
MAIN.C:  Interrupt Driver SIO Using printf.
#include <reg51.h>
#include <stdio.h>
#include "sio.h"
_getkey waits until a character is received from the serial port.  This may not
be the exact desired operation (for example if the buffer is empty, this
function hangs waiting for a character to be received).
char _getkey (void)
int k;
do
  k = com_getchar ();
while (k == -1);
return ((unsigned char) k);
bit get_parity (volatile char ch)
  ACC = ch;
  return (P);
char putchar (char c)
volatile unsigned int i;
TB8 = get_parity(c);
while (com_putchar (c) != 0)
  for (i=0; i<1000; i++)
    /*** DO NOTHING ***/
return (c);
Note that the two function above, _getkey and putchar, replace the library
functions of the same name.  These functions use the interrupt-driven serial
I/O routines in SIO.C.
code char message [] =
  "This is a test to see if the interrupt driven serial I/O routines really work.";
void main (void)
com_initialize ();              /* initialize interrupt driven serial I/O */
EA = 1;                         /* Enable Interrupts */
//printf ("Interrupt-driver Serial I/O Example\r\n\r\n");
  putchar(0xfc);
  putchar(0x05);
  putchar(0x40);
  putchar(0x2b);
  putchar(0x15);
while (1)
  unsigned char c;
//  printf ("Press a key.\r\n");
//  c = getchar ();
 // printf ("\r\n");
 // printf ("You pressed '%c'.\r\n\r\n", c);
  • Dear Andy,
    With your observation, re-reading the posting makes everything clear.
    You are right, there is a lot of things going on after the ACC is loaded with c and the program updates P and the actual transmission. There was a thread somewhere that calls attention to manglign the contents of ACC in C language, but I was reckless.
    Now - after your advice - I load ACC right before loading SBUF.
    And the bill acceptor is getting the message!!!
    Thank you very much,
    Ed
  • Dear Andy,
    Ed
