For my project I need to copy the application ROM image to an external memory. Then I need to know the end of the image. In the linker doc I find the value "Image$$ER_IROM1$$Limit" (I use a scatter file) that should be the first address after the load region. However there are 0x34 bytes more written to the flash, and also they are needed.
Does anyone know: How can I reference to find the end of these very last data? I tried "Image$$LR_IROM1$$Limit" (load region name), but that was not known by the linker. Is &Image$$ER_IROM1$$Limit + 0xd safe to use (i e can I trust there will always be 0x34 bytes and not more?)?
Regards
Jokke
It seems these bytes are used for rw data compression. I could avoid them by using attribute "NOCOMPRESS" in the scatter file. Still, it would be good to be able to know the end of the needed ROM area.
Do you want to executed program code in RAM. If so, you can find information about this in ..\Keil\ARM\HLP\RVI.CHM - Embedded Programs - Specific Memory Areas.
