I have problem when use printf function in Keil uvision when select Realview Compiler ( Not Keil CARM Compiler ) . it can compile ( not have error ) but not have any response send to serial port.
system = LPC2103 + 12.000MHz + RealView MDK-ARM 3.03q Evaluation
#include <LPC2103.H> #include <stdio.h> void init_serial0 (void);
int main(void) {
init_serial0(); printf("Hello LPC2103 TEST UART-0\n");
while(1); }
void init_serial0 (void) { PINSEL0 |= 0x00000005; U0LCR = 0x83; U0DLL = 97; U0LCR &= 0x7F; }
But when i write sendchar , sendstr and sendhex functions same MCB2103 Blink Sample code. it work !!
http://www.keil.com/support/man/docs/mcb2103/mcb2103_examples.htm
..thank you very much
printf requires a retarget.c file. Did you add this file to the project?
