I tried to compile the code written in C++ which there were sevaral Class data types used. Does Keil support CLASS type data? if not, how do I work around it? replace by STRUCT may be ? Please kindly post your reply on this forum. Thanks in advance. JIMMY
"You will have to rewrite the C++ code into C" ... and a 'struct' may not suffice.
Keil is a "C" compiler not a "C++" compiler. You will have to rewrite the C++ code into C.
