Hi all, I received message "*** APPLICATION REQUIRES RE-TRANSLATIONS! ***" from keil c51. What is the message mean? Thank you. Best regards, Akram
if you look up and right, you will see the word "search" Try it Erik
Hi Erik, I found some message: RE: Re-translations -------------------------------------------------------------------------------- It means enough has changed that the linker must recalculate the register coloring (my interpretation). It is benign (informational only), ignore it. - Mark Is there any other detail explanation about it? Thank you. ---Akram
I think that pretty much sums it up!
"Is there any other detail explanation about it?" Yes. At a minimum, you should read about "REGFILE" in the both the compiler and linker manuals.
http://www.keil.com/support/man/docs/c51/c51_regfile.htm http://www.keil.com/support/man/docs/lx51/lx51_regfile.htm http://www.keil.com/support/search.asp?SA=8051&KW=&DY=&PL=&Q=REGFILE&KB=ON&PG=1&PX=1&AV=ON
Hi All, Thanks for your help. Best regards, Akram
