Redifinition Error
Dear all,
I have compiled the following program and am getting redifinition error. I have not redifined the function anywhere, Please help.
Following is my code:
// SFR description needs to be included
#include <reg932.h>
#include "timer.h"
#include "eeprom.h"
#include "port.h"
// flag that indicates if the EEPROM is busy or not
//static bit meeprombusy;
//bit bdata flags;
//s/bit combit = flags^0;
//extern bdata int combit flags;
//** Main Program ** //
void main(void)
interrupt_enable();
ports_init();
eeprom_init();
eeprom_initread();
if(DEEDAT =! 0)
timers_init();
else
eeprom_readloc1();
eeprom_readloc2();
eeprom_readloc3();
eeprom_readloc4();
loadvalues
timers_starttimer0();
timers_stoptimer0();
DESC: Initializes timers
Timer 0 generates an interrupt every 1s
Timer 1 is not used
RETURNS: Nothing
CAUTION: If interrupts are being used then EA must be set to 1
after calling this function
void timers_init (void)
// configure timer 0
TMOD &= 0xF0;
TMOD |= 0x01;
TAMOD &= 0xFE;
// timer values
TH0 = 0xff;
TL0 = 0xfe;
// set timer 0 isr priority to 0
IP0 &= 0xFD;
IP0H &= 0xFD;
// enable timer 0 interrupt
EA = 1;
ET0 = 1;
// start timer 0
TR0 = 1;
} // timers_init
DESC: Timer 0 Interrupt Service Routine
RETURNS: Nothing
CAUTION: timers_init must be called first
EA must be set to 1
void timers_isr0(void) interrupt 1 using 1
// reinitialize
TH0 = 0xC0;
TL0 = 0x00;
DESC: Starts timer 0
RETURNS: Nothing
void timers_starttimer0(void)
TR0 = 1;
} // timers_starttimer0
DESC: Stops timer 0
RETURNS: Nothing
void timers_stoptimer0 ( void )
TR0 = 0;
} // timers_stoptimer0
DESC: Initializes the EEPROM. Enables EEPROM interrupt
RETURNS: Nothing
CAUTION: Set EA to 1 after calling to enable all interrupts
void eeprom_init
void
// initially eeprom is not busy
meeprombusy = 0;
// set isr priority to 0
IP1 &= 0x7F;
IP1H &= 0x7F;
// enable eeprom interrupt
EIEE = 0;
unsigned char eeprom_initread
unsigned int address // 9-bit address to read (0x000 - 0x1FF)
// wait for previous operation to complete
while (meeprombusy);
// eeprom now busy
meeprombusy = 1;
// store bit 8 of address
// byte operation, clear interrupt flag
DEECON = (address >> 8) & 0x01;
// store bits 0-7 of address
DEEADR = address & 0xFF;
// if not using interrupt then poll for end of operation
if (!EA || !EIEE)
// wait for operation to complete
while (!(DEECON & 0x80));
// eeprom no longer busy
meeprombusy = 0;
// return value
return DEEDAT;
return 0x00;
unsigned char eeprom_readloc1
// eeprom now busy
meeprombusy = 1;
if (!EA || !EIEE)
meeprombusy = 0;
// return value
return DEEDAT;
return 0x00;
void interrupt_enable (void)
EA =1;
EX0 =1;
ET0 =1;
void ports_init
void
P0M1 &= 0xFE;
P0M2 &= 0xFE;
P1M1 |= 0x28;
P1M2 &= 0xD7;
P3M1 |= 0x03;
P3M2 &= 0xFC;
} // ports initialisation
