I hava a Infineon Rom Monitor. When I run a hello world program in simulator it is true and "Hello World" write in serial port and I can see in serial window, but when I run in Rom monitor, it can't run and in disassembly window in first line there is :
C:0000 01 ???
But in simulation mode in disassembly window in first line there is:
C:0000 02043D LJMP C:043D
Is there any one can know reason? How can run a program in Rom Monitor?
Is there any one can help me?
"Infineon Rom Monitor"
Have you asked Infineon?
What do their instructions say? In particular, what is supposed to happen if both the ROM monitor and your application are trying to use the same serial port...
"But in simulation mode in disassembly window in first line there is:
Is there any one can know reason?"
Are you using the free evaluation version?
