Save data in EEPROM power failed???
HI,
I am wondering how to save a variable's value in case of power reset. I using AT89C51ED2 internal EEPROM..
what i done recently is i can write in data into EEPROM and read from it, but the problem is that once i reset the power, the data inside the EEPROM all gone too...
below is some part of my program..
unsigned char read_8bit_EEPROM (unsigned int adr)
        unsigned char val;
        bit ea_save;
        while (EECON&1); //wait while busy
        ea_save=EA;
        EA=0;
        EECON |= 0x02;//Enable eeprom data;
        val=*(unsigned char xdata*)adr;
        EECON &= ~0x02;//Disable eeprom data;
        EA=ea_save;
        return val;
// Write EEPROM 8-bit 'val' at address 'adr'
void write_8bit_EEPROM (unsigned int adr, unsigned char value)
        bit ea_save;
        while(EECON & 0x01);
        ea_save=EA;
        EA=0;
        *(unsigned char xdata*)adr=value;
        EA=ea_save;
unsigned char chk_btn(void)
        unsigned char val;
        if(SAVE==0)
                delay_5ms(); //debounce
                while(SAVE==0);
                delay(2000000);
                        LCD_com(0x01);
                        LCD_print(0x30);
                        delay(20000000);
                        delay(20000000);
                        val=0x30;
          return val;
void main()
        unsigned char nv;
        //init_timer1();
        while(1)
        {       DX=0; //set the voltage to 5v
                LCD_init();
                LCD_print(read_8bit_EEPROM(0x10));
                delay(20000);
                 nv=chk_btn();
                write_8bit_EEPROM((0x10),nv);
