89S8252 Internal EEPROM
89S8252 is having internal 2kb of EEPROM,that is defined in the xdata memory space i want to create a structure having the following content,But to write in that memory it require some different method.
xdata struct EEPROM {
unsigned int Last_Data; struct EEPROM xdata *Node; };
struct EEPROM xdata * xdata p _at_ 0x0000;
but if i am simulating this program data is not in the EEPROM but it is in the xdata RAM space
