Problems when using printf
Hi !
My program crashes when using printf(). I use MDK ARM V3.0 together with KEIL-Debugger an ARM STR7-Controller.
When program runs in debugger -> no problem.
When disable interrupts -> no problem
When I change the file scat.scf to start the program from address 0x40000000 -> no problem
But I want to use the IAP-Driver in sector 0 and so my program should be able to start at 0x40002000. Is there something wrong with interrupt vectors ?
My program is based on the KEIL-IAP example.
Has anyone on idea?
best regards
Marc
