SK-XC164CM Easy Kit in combination with the ULINK device
I've started using the "SK-XC164CM Easy Kit" board from Infineon. An USB wiggler was included, but this doens't work properly. I get errors while debugging. (Downloading works). Since i've also have an ULINK device, I want to use this one to download and to debug. But the ULINK doesn't seem to recognise the XC164CM device. Does anyone use this startkit in combination with an ULINK device?
Best Regards,
Henri
  • Did the Ulink come with your Starter kit? If not, then check the Ulink internal connector for OBDS instead of JTAG. If I'm not mistaken, the XC164 is not true JTAG.
    The reason most people have dropped wigglers is billy gates and his crew decided to re-design the parallel port definition. Wigglers will work some of the time on some of the computers some of the days of the week but not often.
    Bradford
    Bradford
