hi.. i want to know that, in my program i have two modules of named fun1 and fun2 which are stored in seperate files. now i want to call those functions from main program which is stored in seperate one. please help me..
"how to access two function programs from main program" Note that you have only one program. That one program consists of three functions - main, fun1, and fun2. Presumably, these three functions are implemented in three separate files - say, main.c, fun1.c, and fun2.c? As Hans-Bernhard says, if you really don't known how to call functions between separately-compiled files, then you need to do some basic 'C' textbook study. However, if you just want to know how to do multi-file projects using the Keil tools, then you need to start by reading the uVision Getting Started Guide, and working through the example projects in it. This will give you a proper introduction to the tools, how they work, and how to use them - rather than just jumping-in blindly at the deep end. (The uVision Getting Started Guide is available on the 'Books' tab in the 'Project' Window; The 'Books' window is also available via the 'Help' menu; failing all that, search for GS51.PDF in your Keil folder)
This is a very question about programming in C. It has basically nothing to do with C51 in particular. This has two important consequences: 1) You really should acquire working knowledge on C programming before you delve into embedded C, on an 8051 of all things. You're trying to run before you mastered walking. 2) You're asking in the wrong place. Basic C questions are best addressed to Usenet forums like comp.lang.c or alt.comp.lang.learn.c-c++
