hi can anybody plz tell is there is an ISP for atmel 89c52 TQFP package...b'coz how will i program it one it si solrded in the ckt board..and ididnt find any adapter for converting 40 pin DIP to tqfp....i find dip to PLCC
thnx mark i have solved the problem using a adpater
Hi, Atmel's datasheet says it has "8K Bytes of In-System Reprogrammable Flash Memory". You may want to look at using FLIP from Atmel if you still need to reprogram the chip once it has been soldered to the board, or now you have the adaptor have you solved your problem? Mark.
i got a DIP to TQFP adapter so that i can download thru a programmer
