Hello, i'm using the XC164-µC with internal Ram at 0xC000-0xC7FF (DSRAM) & 0xF600-0xFDFF (DPRAM).
When I use 'standard' Target Layout Memory. I get a Linker Section NDATA(0xC000-0xC7FF,0xF600-0xFDFF) and I could use 4k (-Stacksize) for NEAR DATA.
If I would use more than 16kB for NCONST I select 32kB for ROM in NEAR MEMORY-Section(@Target-Layout).
In L166 LOCATE I get following line: DPPUSE (0=NDATA(0xC000 - 0xC7FF), 1=NCONST(0xC00000 - 0xC07FFF))
The DPRAM (0xF600-0xFDFF) is now not used for NEAR DATA!
How can I use this RAM also for NEAR DATA like in the case without DPPUSE?
ciao, Karl
Ps:The XC164-16CS claims that it has 8kB internal Data. But I only found 2kB DSRAM (0xC000-0xC7FF), 2kB DPRAM(0xF600-0xFDFF) and 2kB PSRAM (0xE00000-0xE007FF). Where are the remaining 2kB located?
Hi Karl,
I don't no much about the XC164 specifically but maybe you could assign the whole range (C000-FDFF) in the DPPUSE directive and use the RESERVE directive to disable the areas where there's no RAM?
http://www.keil.com/support/man/docs/l166/l166_reserve.htm
Or take a look at the CLASSES directive and add the correct ranges for the NDATA class?
http://www.keil.com/support/man/docs/l166/l166_classes.htm
Doesn't the datasheet/user manual for an XC164 have a memory map?
Rergards, Joost Leeuwesteijn
PS. What does DS(RAM), DP(RAM) and PS(RAM) stand for?
@Joost: It works to assign the whole adress range in DPPUSE and define a smaller class for NDATA.
Thank you for the tip!
@Chris Which Version of the XC164CS-16F System Manual do you have? I have Version 2.1(March 2004) from the Infineon Homepage. In this Document on page 3-3 the adressrange for DSRAM is 0xC000-0xC7FF. But in the Datasheet for the XC164CS-16F they claim that there are 4kB DSRAM. Now I have seen that the DataSheet is from March 2006. Is there a newer Version of the System-Manual available?
No, I was looking at the 256k (32) version which has the same DSRAM amount as the 128k (16) version, 4KBytes.
Which is V1.0 (May 2004)
According to our Infineon FAE, the -16F has always had 4k of DSRAM but Infineon only advertised and tested 2k of it which is why the 2004 datasheet says 0xC000-0xC7FF. They later decided to test and offer the entire 4k block which is relected in the newer datasheet.
@Walter
In the Datasheet there is the statement of 4kB. But they 'forget' to correct it in the Systemmanual (and the Memorymap is only in the Systemmanual).
And in the Keil µVision there is also only the first 2kB mentioned.
