Hi All,
I've just installed the RealView MDK-ARM product ver. 3.03a, but the os sys_init_user don't work correctly. Moreover, my project entry in the os_clock_demon but don't exit from it.
Could you please help me? thanks
"don't work correctly."
Would you care to be a little more vague about that?
Well.....when I call os_sys_init_user my project go to the Data Abort Expetion. Moreover, If I call a task by mean os_sys_init_prio with a priority different to 1, the kernel assign of my task always the priority equal to 1.
I hope to has been a bit more clear....:-))
You did not mention your device type so I suggest that you attempt to run some of the simple RTL examples in the ARM directories. The old reliable Blinky is a good example to try the features of RTL. Just from your very brief comments, I would GUESS that you are pointing to the wrong Lib files.
Thanks for the answer.....the divice is Atmel AT91SAM7S256 (ARM7 Core).....In any case, I got the Lib files from Keil web site, so I don't think that it is wrong...
