Can't return from C func called from ASM
Hello. I have an existing ASM progrom which I am going to convert, as needed, to C. I was succesful at overriding the UART interrupt function (in C). Now, in my main ASM loop I need to check for recieved chars which I will doing in C. When I call my C func from the MAIN func in ASM the 8051 appears to go into a reset loop and will not successfully boot.
My C Func:
code void CheckForRx (void)
if (RxCount!=0) //C global inc'd in INT
DoSomething();
My ASM Main:
extern code (CheckForRx)
Start:
;Do alotta other stuff
lcall CheckForRx
jmp Start
I get no linker warnings (it finds my C func) however that call will not work. Remove the lcall CheckForRx and the system works again.
Any ideas of what I have most likely looked over?
Thanks, Chris
